Wrekavoc is an heterogeneity emulator. In the context of the evaluation of distributed applications and systems, experimenters use it to define the heterogeneity of a given platform (typically a cluster) by degrading CPU, network or memory capabilities of each node composing the platform. Wrekavoc is freely available, and runs on Linux.
Download
Publications
Main publication (use it to refer to Wrekavoc)
- Louis-Claude Canon, Olivier Dubuisson, Jens Gustedt and Emmanuel Jeannot.
Defining and Controlling the Heterogeneity of a Cluster: the Wrekavoc Tool
Journal of Systems and Software, Volume 83, Issue 5, May 2010, Pages 786-802.
HAL -
PDF (research report) -
Bibtex
@article{Canon:2010:DCH:1750579.1750614,
author = {Canon, Louis-Claude and Dubuisson, Olivier and Gustedt, Jens and Jeannot, Emmanuel},
title = {Defining and controlling the heterogeneity of a cluster: The Wrekavoc tool},
journal = {J. Syst. Softw.},
volume = {83},
issue = {5},
month = {May},
year = {2010},
issn = {0164-1212},
pages = {786--802},
numpages = {17},
doi = {http://dx.doi.org/10.1016/j.jss.2009.11.734},
publisher = {Elsevier Science Inc.},
address = {New York, NY, USA},
Other publications
- Tomasz Buchert, Lucas Nussbaum and Jens Gustedt. Methods for Emulation of Multi-Core CPU Performance
INRIA Research Report 7450. November 2010
HAL -
PDF -
Bibtex
@techreport{BUCHERT:2010:INRIA-00535534:1,
title = { {M}ethods for {E}mulation of {M}ulti-{C}ore {CPU} {P}erformance},
author = {{B}uchert, {T}omasz and {N}ussbaum, {L}ucas and {G}ustedt, {J}ens},
type = {Research Report},
institution = {INRIA},
number = {{RR}-7450},
month = {11},
year = {2010},
- Tomasz Buchert, Lucas Nussbaum and Jens Gustedt. Accurate emulation of CPU performance
8th International Workshop on Algorithms, Models and Tools for Parallel Computing on Heterogeneous Platforms (HeteroPar'2010)
HAL -
Bibtex
@InProceedings{heteropar-fracas,
author = "Tomasz Buchert and Lucas Nussbaum and Jens Gustedt",
title = { Accurate emulation of CPU performance },
booktitle = {8th International Workshop on Algorithms, Models and Tools for Parallel Computing on Heterogeneous Platforms (HeteroPar'2010)},
address = "Ischia, Italy",
year = "2010"
- Olivier Dubuisson, Jens Gustedt and Emmanuel Jeannot. Validating Wrekavoc: A tool for heterogeneity emulation
Heterogenity in Computing Workshop (HCW 09) in International Parallel and Distributed Processing Symposium - IPDPS 2009
HAL -
PDF -
Bibtex
@inproceedings{DUBUISSON:2009:INRIA-00435609:1,
title = { {V}alidating {W}rekavoc: {A} tool for heterogeneity emulation},
author = {{D}ubuisson, {O}livier and {G}ustedt, {J}ens and {J}eannot, {E}mmanuel},
booktitle = {{H}eterogenity in {C}omputing {W}orkshop ({HCW} 09) in {I}nternational {P}arallel and {D}istributed {P}rocessing {S}ymposium - {IPDPS} 2009 {IEEE} {I}nternational {S}ymposium on {P}arallel \& {D}istributed {P}rocessing, 2009.},
address = {{R}ome {I}taly },
year = {2009},
- Olivier Dubuisson, Jens Gustedt, and Emmanuel Jeannot. Multi-Site Emulation using Wrekavoc: Validating Distributed Algorithms and Applications
INRIA Research Report 6696. October 2008
HAL -
PDF -
Bibtex
@techreport{DUBUISSON:2008:INRIA-00331627:1,
URL = {http://hal.inria.fr/inria-00331627/en/},
title = { {M}ulti-{S}ite {E}mulation using {W}rekavoc: {V}alidating {D}istributed {A}lgorithms and {A}pplications},
type = {{R}esearch {R}eport},
number = {{RR}-6696},
year = {2008},
- Louis-Claude Canon and Emmanuel Jeannot. Wrekavoc: a Tool for Emulating Heterogeneity
15th IEEE Heterogeneous Computing Workshop (HCW 06), April 2006
PDF -
Bibtex
@inproceedings{
title = {Wrekavoc: a Tool for Emulating Heterogeneity},
author = {Louis-Claude Canon and Emmanuel Jeannot},
year = {2008},
booktitle = {{H}eterogenity in {C}omputing {W}orkshop ({HCW} 06) in {I}nternational {P}arallel and {D}istributed {P}rocessing {S}ymposium - {IPDPS} 2006 {IEEE} {I}nternational {S}ymposium on {P}arallel \& {D}istributed {P}rocessing, 2006.},
address = { Island of Rhodes, Greece},
year = {2006},
Contact
The original developer of Wrekavoc is Emmanuel Jeannot. Any question, remark or suggestion should now be sent to Lucas Nussbaum (lucas.nussbaum@loria.fr), who is now maintaining Wrekavoc.
Other contributors to Wrekavoc by order of appearance: Jens Gustedt, Louis-Claude Canon, Olivier Dubuisson and Tomasz Buchert.
